I strongly feel that something is wrong with:
- Configuration
- Device capability
- Scenario not reproduce. (Condition not met)
Yes, inter eNB CA is not available everywhere I think.
This is because they don’t want cross carrier aggregation.
I checked all from my end still looking if it can work.
Check with any one site which is working and check it’s license and parameter compare you may get it when nothing works this works.
S_Measure has significance in connected mode as well?
Yes, for connected mode only.
During your trial, what S_measure you have kept?
I guess 0 mean less than -140 dBm.
Please keep it highest value. Like 97 (-43 dBm).
0 means it not used.
I thought the same earlier, but then how represent RSRP >-140 dBm?
I confirmed that value 0 means s-measure not started.
It means UE will not measure intra/inter frequency.
So try again with s-Measure value 97 and check whether UE rwports A6 or not
Ok let me check again👍
No dear with s_measure 0 UE sending inter Freq MR.
But he just asked you to make s-measure=97.
And only after that to test again.
Already set to 0 for which I given result.
97 I will.
If mgap is configured, then even though s-measure is set to 0 UE can send MR.
In my case it’s CA where scell added and UE sending Inter Freq MR on same so no need of drx / mgap.
Yes, so this is also possible.
Without CA, s_measure 0 with meas gap UE sending Inter Freq MR which is ok.
If no meas gap, then no MR irrespective value of s_measure.
Intra freq MR can be sent without mgap, if serving rsrp is less than s_measure.
