Intra not required mgap.
Did tried with s_measure 97?
Yes working fine. It’s like always meet condition.
Great!
Thanks
A6 issue resolved.
Point to note it’s always used with scell intra Freq neighbour cells only not valid for inter.
It’s always for intra.
Yes right. PCell also intra also applicable.
Always source cell.
Correction here for s-measure statement: serving level must be above s-measure for Intra freq MR.
Mgap not needed for intra freq.
If s-measure is -60 then UE can only measure intra freq cells if its RSRP is less than -60 (-61dBm and so)
But if serving RSRPvisb -55 dBm and mgap is configured then UE can measure both intra and inter.
You can test above in lab.
I tried it’s not sending intra Freq MR.
With what scenario?
S-measure -80 and serving rsrp intra and inter Freq -70 with mgap configured then ue fail to send MR.
We need to cross -80, i.e. -81.
Was event condition met?
Which MR you were expecting?
Please note scenario without CA where s_measure play very crucial role… MR A5 for intra/inter.
Yes but was your A5 condition met?
Yes once I lower s_measure, i.e. -60 immediately UE send A5.
So in summary: as long as the serving RSRP is greater than S_Measure, it does not measure intra Freq Nbr.
But I didn’t understand your 2nd statement. Are you saying that If A2 threshold is -54 dBm, then measurement gap will initiate…?
I need to check about priority of mgap and s-measure.
