I’m trying to understand why Coverage loss seen.
We always find with 4T4R coverage enhancement!
Because total RU power unchanged, No of Tx ports increased 2 times, so power per Tx reduced half → RS power reduced 3 db.
Pmax in formula for whole rru.
Not per pipe.
No, Pmax is per Tx.
46 dBm how many Watt?
It is 40 w.
Then is it per pipe.
40x4 = 160 watt.
Hope so my point clear.
160 watt equal to 52 dBm.
Per pipe here is 10 watt.
But we consider for RRU.
Can you check RRC attempt pre and post?
Even though you have reduced A2 by 3 dB it will be effective only of Same RRC attempt count is there.
If RRC attempt are reduced, you should change idle mode parameters like threshXLow, ThrehsServingLow, ThreshXHigh from other carriers to this carrier.
If CRS = 18.2dbm, Pa/Pb = -3,1, bw = 10Mhz → Tx port power = 20w, 2Tx = 40w total RU power.
If you want to increase to 4Tx, same power, it will be 20x4 = 80W total RU power.
Yes, I think we need to modify idle mode settings also.
Actually the RRU power is same, in both cases.
Yes, let me try. ![]()
Then any change in tilt or some one used deboost power option on site.
No…To compensate the CRS power loss, we have reduced the A2 threshold by 3 dB.
This point not clear without change in RRU power why CRS power reduced.
A2 used for inter Freq / inter rat trigger.
Why A2 reduced here?
We can play with qrxlevmin.
A2 threshold is for HO.
Yes, change A2 can not help coverage reduce.
Power per port reduced from 20W to 10W.
Hence CRS power reduced by 3 dB.
Ok may be different for Ericsson…
qrxlevmin is only for cell selection and reselection, it cannot guarantee UE holding in idle or active mode.
Yes can used for initial latch can increase no of rrc users.
Other option rs boosting.
Or ET change.
Have you changed A5 threshold in parallel to A2?
Understood ![]()
Yes, It is adjusted as per A2.
Please try above method mentioned.
