One of my n25 site which is new integration having 100% ENDC setup failures vendor is Ericsson.
Can you help what I can check?
Check measurement report there for 5G or not.
I mean B1 event.
SSB frequency , Termpoints, System Constants could be the problem
What if there is nor measurement report for B1 event? What should we check?
better u check through trace, issue could be either neighbor and X2 declaration or consistency, also u need to check the caus efor the SgNB Add Reject using trace u can figure out whats the reason, u can compare normal site config with your site degraded
