Hi Ericsson Experts.
Any suggestions on what to check when we notice degradation in “ENDC inter SGNB PSCELL Change Success Rate” KPI?
Any steps to troubleshoot the issue?
Many thanks.
Many thanks.
Some useful steps for this. Might be helpful to u.
*check endcAtionA3EvalFail its set to release or ignore or something else. Set to default or baseline value as per vendor specific.
*Check TermpointToeNB & TermpointTogNB are set in MeNB and Enabled. exmpl like MO configured in MeNB for source gNB, target gnb @MeNB for source gNB. This is very crucial if anything missed here… U will get inter PS CC HO failures in SgNB hence failure counter will peg and degradation in HO SR % .
*Check in any case MeNB is refusing for SGNB CHANGE over x2AP. DT log analysis & rrc connection RECONFIGURATION mesaage for details about target sgnb addition. Whether enb is acknowledging this or not. because MeNB is the one which evaluate the target NR cell suggested by source gnb. if any mismatch during this evaluation… than failures may happen so verify the above point and its parameters as well.
*gNB detected RLF during ongoing SgNB, coverage gaps, High ISD etc.
*Check packet forwarding from both source gNB and target gnb and its parameter settings. All OK or not
*Fianlly TDCOverall timer expiry. it should not be set to too low or to high.
Also Check any outages on nearby NR/LTE sites.
*check LTE KPIs and also HW related logs for any intermittent alarms/failures.
Typically missing relations from LTE anchor (of NR source) to NR target
