Should be like this in rrc reconfig:
Compare all ENDC parameters of L2100 vs L1800.
And correct the descrepancies if any.
Thanks.
Ok, any simple method to do quick check?
Try with Notepad++
Export both xml and then compare.
Or with ultraedit.
Or use ultracompare: Enter your information to download UltraCompare for Windows
XML export through ENM?
I have only AMOS access need to check ENM access.
BeyondCompare is good option too.
I think you need MFBI
Is SSB defined correct and check termpoints are defined correctly or not…
