ZTE eNodeB (LTE) CLI Command Reference – Baseband Parameters & Configuration
Hi ZTE Experts,
I have a quick question regarding the CLI on ZTE LTE eNodeB.
Does anyone have a handy command reference or guide for the ZTE eNodeB CLI?
Specifically, I’m looking for:
  • The correct syntax to display and modify basic baseband parameters (e.g., rxLevMin, PCI, etc.)
  • Commands used to extract current configuration parameters
  • Commands used to adjust or apply configuration changes
Any documentation, examples, or practical tips would be great.
It involves modifying an Excel file in ZTE.
Ahh, I saw it in the documentation - is that the only way?
There is also a CLI option, but it’s quite complicated.
Using Excel for bulk configuration is faster, more secure, and generally the easiest way to make changes.
