Hi, I would like to trigger a x2 handover during execution phase to observe 2 different chipset of the device.
normally when handover is not triggered or failed, UE still moves to target cell with TAU active flag QCI9-5.
To simulate a x2 ho failure execution , what we can do in bts?
I have tried t304 timers, s1ho is already blocked. only allowed x2 ho
target cell coverage cant be attenuated quickly, only step by step.(no digital atenuation)
i have tried creating pci conflict, same pci source/target cell same rootseq index (this is a prep failure)
Thanks!
Note: This test is to be done under lab node.
It seems you are in a controlled environment so my only advice is to do it while UE trace is running on in PCC and you can see a live screen while you are doing it.I know this can be achived via Ericsson PCC.
You might need to trigger RACH failure.
I am not sure about nokia config but typically this could be done by having the UE outside the configured cell range/radius. This range/radius is typically corrolated to zero correlation zone config of random access
Forget about the source
For the target, ZCZC related to certain cell radius. If UE is away from the target by more than this distance, RACH fails and hence HO fails
This could be done via actual distance of by introducing delay in transmissions e.g DAS
