Winfiol automatic login script and maintenance script for nodes
Dear Experts,
I need your support to get the script for winfiol on automatic login to the bsc and also the script (macro) for automatic scripts .
BR//
Hi, @Sebastiansilver, for autologin you need to set up login data in channel properties. For ports 5000 and up you need only login and password. Add promt or end part of promt and answer. Also you can add this lines to the file.
Other part of your question I don’t understand, sorry. Can you explain it?
Hi ,
Thank you so much for the reply , I said that I am looking for the script to run in the winfiol for automatic login and I need script for general O&M script for the BSC.
BR//
Hello, I created a login here just to say thank you, because the print you posted was exactly what I needed.
