UE is not reporting A5 measurement for inter frequency cell.
Gnb configuring meas object and report config and meas gap
In UE logs ue is not measuring neighbor cell
UE attach is working to that inter frequency cell
UE is able to report intra frequency cell but not reporting inter frequency cell
Any suggestions?
wa3
April 24, 2023, 12:18pm
2
Please check if ANR is enabled or not.
And also sctppeer is updated or not.
wa3
April 24, 2023, 12:19pm
4
It should be enabled.
Else how the neighbours will be updated?
Looks like Thresholds are not proper or condition for A5 is not meeting.
As per original query it stats about measurement report for inter cell, it does not matter wether ANR is enabled or disabled.
Thresholds are fine.
Any other conditions I need to check?
Neighbour measurements are not there in UE log.
I feel UE is not switching to neighbour frequency.
wa4
April 24, 2023, 12:40pm
7
I think neighbor relations need to check in MO dump.
If no relations with neighbor require to enable ANR or perform manually neighbor creation.
LordGm
April 24, 2023, 3:31pm
8
hi, if UE does not report A5 that means either condition thresh1 and thresh2 are not fulfilled
or UE cant measure the target SSB, Check your NRHOIF/Interfreq object ifhossbsmtcduration and smtc periodicity parameters. Configure them as sf4 / sf40.
it is not about ANR, you can manually configure neighbour
Please share source and target beam setting and ssb periodicity so we answer ur question.
Ashok_Reddy:
Are you able to see from UE log serving cell goes below the configured as in A5?
O.B
April 25, 2023, 1:08am
11
Source and target cells are not synchronized
