Imagine opening Google Maps. Does it render the entire city at once?
Of course not.
It renders only the area you’re currently viewing, making navigation faster and reducing unnecessary processing.
5G NR follows the same philosophy.
A carrier may span 100 MHz, but a UE doesn’t continuously process the entire bandwidth.
Instead, it operates within an Active Bandwidth Part (BWP)—a configurable portion of the carrier that contains the resources it currently needs.
Why is this important?
• Lower FFT processing complexity
• Reduced power consumption
• Flexibility to switch BWPs based on traffic and service requirements
The entire carrier is always available, but the UE only “looks at” the bandwidth part that is active at that moment.
Just as Google Maps doesn’t render an entire city to show your current location, a 5G NR UE doesn’t process the entire carrier to receive its data.
Sometimes, the smartest engineering solution isn’t adding more resources—it’s processing only what’s necessary.
