I see only UE reading paging message only not sending any reply back to network.
Without RRC connection, there is no data on VoLTE.
UE is downloading, means alreay has RRC connection.
Also check out the Paging with IMSI, and its handling.
This may be the case when UE is in connected state.
Paging Cycle.
What is reason of paging message coming in connected mode?
sib11, sib12 not there.
What info eNB/Core to send UE in connected mode?
UE always monitor SIB meassages in connected mode for possible SIB modifications.
Which SIB in particular?
Any SIB.
Thanks.
What about C plane load?
Will it increase due to this?
I dont think so.
SIB is broadcasted message and not intended to particular UE.
Connected mode is monitored by UE for any SIB change notifications and incoming/MT VoLTE call.
SIB change notifications can be for modified / updated neighbor PCI or ARFCN or CMAS / ETWS.
Hi Experts , why in 5G SA connected mode RRC, there is paging ?
For example, to inform UE to read SIB after some parameter is modified.
Hi Sir, is this screenshot from a simulation software or itβs from real-life communication?
