At mmWave frequencies, a phone cannot simply listen equally well in every direction. Both the base station and handset use highly directional beams to overcome large propagation loss so before high-rate communication begins they need to discover a useful transmit and receive beam pair. This process is called beam search or beam sweeping. The base station transmits reference signals over several candidate directions while the phone measures them and reports which beam provides the strongest or most reliable link.
The problem is that the best beam is not fixed. Rotating the phone, covering one side with your hand or moving behind a wall can weaken one path and make another reflected path better. The handset may therefore repeat beam measurements and switch between phased-array modules or beam states as the radio environment changes. At mmWave, even a small change in orientation can matter because the beams are narrow and the human body can strongly attenuate the direct path.
Beam search therefore creates a tradeoff between speed and overhead. Testing more beam directions improves the chance of finding a strong path but every measurement consumes time and radio resources. Modern 5G systems reduce this burden by using hierarchical searches, beam refinement and previously learned beam information rather than blindly scanning every possible direction every time. The fastest 5G link is therefore not just about having enough bandwidth. The phone first has to find where to point.
Critical Formulas:
a) Steering Phase
ฮฯ = โ(2ฯd/ฮป) sinฮธ
Different phase progressions steer the phased array beam toward different candidate directions.
b) Received Power
Pr โ PtGtGr(ฮป/4ฯR)ยฒ
Directional antenna gains Gt and Gr are especially important at mmWave because free-space path loss is high.
c) Beam Search Time
Tsearch โ Nbeam ร Tmeas
Testing more candidate beams improves directional coverage but increases search time.
d) Beam Selection
b* = arg max_b SINR_b
The receiver selects the beam state that provides the highest usable signal quality rather than simply the highest raw signal level.
- Qualcomm Snapdragon mmWave modem RF platforms use beam management functions to help smartphones discover and maintain directional 5G links.
- Verizon 5G Ultra Wideband mmWave connections rely on narrow directional beams so phones must continually find and track suitable paths as users move.
- NTT DOCOMOโs 28 GHz 5G deployments use beamforming to maintain high capacity links where handset orientation and blockage can strongly affect the best beam.
- Samsung Galaxy mmWave smartphones use multiple antenna modules around the device so beam search can select a better module when one side of the phone becomes blocked.
