Why 5G throughput never matches theory
We’ve all seen the numbers.
Gigabit speeds. Peak throughput. Lab results.
But then you go to the field…
And reality looks very different.
This gap is not a failure of 5G.
It’s a misunderstanding of how radio networks actually behave.
From my experience in RAN optimization, one of the biggest reasons behind this gap is simple:
The network is never operating under ideal conditions.
:pen: Theoretical throughput assumes perfect radio conditions, while real networks operate with interference, load, and variable SINR.
:pen: Peak speeds are calculated for single-user scenarios, but in reality, resources are shared across multiple users competing simultaneously.
:pen: High-order modulation schemes like 256QAM or higher require stable radio quality, which is rarely sustained across the entire coverage area.
:pen: Scheduling decisions prioritize fairness and stability, not just maximum throughput for a single user.
And here’s the key point:
Throughput is not only a radio capability.
It is a system outcome.
It depends on:
:light_bulb: Coverage quality
:light_bulb: Network load
:light_bulb: Device capability
:light_bulb: Scheduler behavior
So when someone asks:
“Why am I not getting the advertised 5G speed?”
The real answer is:
Because the network is doing exactly what it was designed to do.
Balance performance across all users.
Not maximize one.
Understanding this difference is critical.
Because it shifts the conversation from unrealistic expectations…
To meaningful optimization.
Part 1 of a series on 5G THROUGHPUT: REALITY VS THEORY.
Next: THE HIDDEN IMPACT OF SCHEDULING
What’s your experience?
Is the industry doing enough to explain the gap between theoretical and real-world performance?
