Why 5G Is Safer Than 4G - and Still Not Bulletproof
:red_circle: In 4G, your IMSI was sent in plaintext. Any Stingray device could capture it.
5G fixed this. But most engineers don’t know exactly how β€” or where the gaps still exist.
Here’s the complete 5G security breakdown:
:building_construction: Identity Protection β€” How 5G Hides the Subscriber:
β†’ SUPI: Subscription Permanent Identifier β€” replaces the 4G IMSI
β†’ SUCI: Subscription Concealed Identifier β€” SUPI encrypted with HPLMN public key
β†’ UE encrypts SUPI before every attach β€” never sent in plaintext over the air
β†’ SIDF (in UDM) decrypts SUCI β€” only the home network can reveal the real identity
β†’ IMEI: device identity β€” checked against Equipment Identity Register (EIR)
β†’ Result: IMSI catchers and Stingray attacks are blocked at the identity level
:brain: Authentication β€” 5G-AKA and EAP-AKA:
β†’ 5G-AKA: primary authentication β€” challenge-response via AUSF and UDM
β†’ EAP-AKA: used for non-3GPP access (Wi-Fi calling, fixed wireless)
β†’ AUSF: Authentication Server Function β€” verifies the UE identity
β†’ UDM: stores the long-term key K β€” used to derive all session keys
β†’ KAUSF β†’ KSEAF β†’ KAMF: key chain from auth to AMF anchor
β†’ Mutual authentication: both UE AND the network verify each other β€” 4G only authenticated the UE
:light_bulb: The 5G Key Hierarchy:
β†’ K: root key stored in USIM β€” never leaves the SIM
β†’ CK / IK: cipher and integrity keys derived from AKA
β†’ KgNB: derived from KAMF β€” the gNB session key
β†’ KRRCenc + KRRCint: RRC layer encryption and integrity
β†’ KUPenc + KUPint: user plane encryption and integrity (integrity optional but available)
:cross_mark: Where 5G security gaps still exist:
Γ— Protocol downgrade attacks: UE can be forced to 4G where SUCI doesn’t apply
Γ— Null encryption: still negotiable in some operator configurations β€” should not be
Γ— Inter-operator roaming: N32 interface between SEPPs relies on operator trust
Γ— User plane integrity: optional by 3GPP β€” not all operators enable it
Γ— False base station attacks: still possible in some NSA deployments
:white_check_mark: Key Security NFs every engineer must know:
β†’ AUSF β€” authenticates UE, issues KAUSF
β†’ UDM/SIDF β€” stores subscriber key K, decrypts SUCI
β†’ SEPP β€” Security Edge Protection Proxy β€” secures N32 roaming interface
β†’ AMF β€” NAS security context holder, derives KgNB for gNB
5G is the most secure mobile generation ever designed. But security only holds if operators enable all features β€” and engineers understand where the boundaries are.
