Hi 5G Experts.
Anyone knows which wireshark filter to use for SRS signal to see? Sounding reference signal
Hi 5G Experts.
SRS cannot be seen in Wireshark.
It is a reference signal at physical layer in Uplink.
Thanks.
On wireshark I see this option on the filters:
I want to look and see the configuration on “SRS” in RRC.
By Wireshark is it possible?
It is possible to see SRS config in RRC messages but not the SRS signals themselves.
You can see SRS config which will be partof RRC Message.
But you mentioned Signal which cannot be seen.
