Which UE supports 4 Uplink layers in 5G?
Dear all,
Can any one help which UE supports 4 Uplink layers in 5G?
Does Xiaomi Poco 6 support 4 uplink layer?
Where to get UE related detailed specification
Most of UEs doesn’t support MIMO for UL.
Just new flagship like Xiaomi 14 Ultra maybe support 2 layer MIMO.
No phone supports 4 layer for Uplink as I saw.
Ok, thank you!
Can anyone confirm for Xiaomi Poco 6?
Xiaomi poco6 is not yet on cacombos.com.
Sso cannot be verified.
But I also know there are no UEs with 4 UL MIMO in 5G.
Here are the specs:
But MIMO info not available.
Any update on commercial 5G CPEs available in the market that support 2 or 4 UL layers?
If anyone has information, please share websites, contacts, or links where these can be found.
There are 5G UEs with 2x2 UL MIMO, but only for a few bands.
You can find them on cacombos.com.
Oh, okay. Thank you! I am specifically looking for the n78 band.
You can refer to the Samsung S22 and OnePlus 10 Pro, both of which support MIMO and Band b78.
I am specifically looking for an outdoor CPE that supports the n78 band.
This Huawei CPE supports it:
Huawei 5G Outdoor CPE N5368X (N5368X) 5G
Check here Huawei 5G Outdoor CPE N5368X (N5368X) | 4G/5G Bands & Combos
It has 2 UL MIMO layers in Uplink in 5G alone.
That means SA not NSA!
Actually, all 5G UEs on the market support 2 UL layers in MIMO only in 5G SA. I couldn’t find a single one that supports it in 5G NSA.
There are many options available, such as the Apple iPhone 16 Plus (A3290), Qualcomm MTP8650-5G, OnePlus 12 (CPH2581), and Telit FN990A40.
Additionally, options like the Sony Xperia 1 II 5G, MediaTek MTK DUJAC M80, and WNC Pocket 5G Router R3 are also worth considering.
Most phones do not support 4 uplink layers in 5g, and the POCO 6 also doesnt support it. For device details, you can check cacombos or the phone official specifications.
