Q. Which SIP Response does the P-CSCF use to know the S-CSCF address the user registered on?
a) 183 Session Progress
b) 401 Unauthorized
c) 200 OK
d) 380 Alternative Services
Check 🔎
Correct answer: Letter c.
During the IMS registration process, once the HSS selects and returns the S-CSCF to the I-CSCF, the REGISTER request is routed to the S-CSCF. After successful authentication and registration, the S-CSCF responds with a 200 OK, which is passed back to the P-CSCF.
This 200 OK response contains critical headers such as:
- Path header: used by the P-CSCF to maintain the SIP signaling path.
- Contact and Service-Route headers: these include the S-CSCF URI, informing the P-CSCF of the serving call session control function.
a)
→ Incorrect. This is used for early media during session setup — not for registration.
b)
401 Unauthorized
→ Incorrect. Used for SIP authentication challenges, not for learning S-CSCF addresses.
c)
200 OK
→ Correct. After successful SIP REGISTER, the S-CSCF returns a 200 OK, containing the Service-Route header that tells the P-CSCF which S-CSCF is serving the user.
d)
→ Incorrect. This response is used to indicate alternative services or routes, but not used in this context.
- **“Use the reference coupon below for a significant discount on the course.”**https://www.udemy.com/course/practical-analysis-for-volte-call-flows-using-wireshark/?couponCode=TELECOMHALL
