Q. Which one is NOT the focus of 5G?
a) Massive connectivity.
b) Ultra high speed data.
c) Low cost per gigabyte of data.
d) Low latency.
Check π
Correct answer: Letter c.
5G is built around three main pillars: eMBB (enhanced Mobile Broadband), URLLC (Ultra-Reliable Low Latency Communication), and mMTC (massive Machine Type Communications). While lowering costs per GB is beneficial, it is not a defined technical objective in 5G standards.
a)
β Incorrect. This is a key goal under mMTC, enabling support for billions of IoT devices.
b)
β Incorrect. A major 5G target under eMBB, delivering gigabit-class speeds.
c)
β Correct. While important for business models, itβs not a core technical goal of 5G.
d)
Low latency.
β Incorrect. One of the main pillars under URLLC, enabling real-time applications like autonomous driving.
