Q. Which one below indicates the best signal strength?
a) RSRP = ā71 dBm
b) RSRP = ā93 dBm
c) ARPU = 50
d) Throughput = 24 Mbit/s
Check š
Correct answer: Letter a.
RSRP (Reference Signal Received Power) measures signal strength in LTE/5G. A value closer to 0 dBm (less negative) means stronger signal. So ā71 dBm is better than ā93 dBm. ARPU and Throughput are not direct signal strength indicators.
a)
RSRP = ā71 dBm
ā Correct. Less negative RSRP values (like ā71 dBm) indicate stronger signal reception.
b)
RSRP = ā93 dBm
ā Incorrect. Although still usable, ā93 dBm is weaker than ā71 dBm.
c)
ARPU = 50
ā Incorrect. ARPU (Average Revenue Per User) is a financial metric, not related to signal strength.
d)
ā Incorrect. Throughput reflects data rate, not raw signal strength.
