Q. Which of these is NOT a part of IMT-2020 high level vision?
a) eMBB
b) Voice
c) mMTC
d) URLLC
Check š
Correct answer: Letter b.
Voice is not explicitly defined as part of the IMT-2020 high-level vision. The IMT-2020 vision focuses on three key usage scenarios: eMBB (enhanced Mobile Broadband), mMTC (massive Machine-Type Communications), and URLLC (Ultra-Reliable Low-Latency Communications). While voice services are supported over these frameworks, they are not a specific IMT-2020 category.
a)
eMBB
ā Incorrect. eMBB (enhanced Mobile Broadband) is one of the three main IMT-2020 pillars.
b)
Voice
ā Correct. Voice is a service enabled over 5G, not a defined part of the IMT-2020 vision categories.
c)
mMTC
ā Incorrect. mMTC (massive Machine-Type Communications) is a core IMT-2020 usage scenario.
d)
URLLC
ā Incorrect. URLLC (Ultra-Reliable Low-Latency Communications) is a key component of IMT-2020.
