Q. Which DNS Query type is resolved to an IP address?
a) SRV Query Request
b) NAPTR Query Request
c) A Query Request
d) PTR Query Request
Check 🔎
Correct answer: Letter c.
A Query Request is a DNS query used to directly resolve a hostname into an IPv4 address. In the VoLTE/IMS architecture, this is the final DNS resolution step that yields the actual IP address of a network entity (like P-CSCF, S-CSCF, etc.).
a)
SRV Query Request
→ Incorrect. SRV (Service) records return the hostname and port of servers that offer a specific service (like SIP over UDP). You still need to perform an A/AAAA query to get the IP.
b)
NAPTR Query Request
→ Incorrect. NAPTR (Naming Authority Pointer) records are used for dynamic service discovery, such as translating a SIP URI into a service endpoint. NAPTR typically leads to SRV or A/AAAA queries, but doesn’t resolve directly to IPs.
c)
A Query Request
→ Correct. A records are the DNS record type that maps a fully qualified domain name (FQDN) directly to an IPv4 address — exactly what’s needed to establish an IP-level connection.
d)
PTR Query Request
→ Incorrect. PTR (Pointer) records are used in reverse DNS lookups, translating an IP address back into a hostname, not the other way around.
- “Use the reference coupon below for a significant discount on the course.”
