Q. When the caller hangs up first, which direction is the BYE sent?
a) S-CSCF → HSS
b) P-CSCF → PCRF
c) Callee → Caller
d) Caller → Callee
Check 🔎
Correct answer: Letter d.
In SIP/IMS, when the caller hangs up first, a BYE message is sent by the caller to terminate the session. This BYE is routed through the IMS entities toward the callee.
- The BYE message is part of the SIP signaling used to terminate established sessions.
- It follows the same SIP path as the initial INVITE, in reverse.
- No need to contact the HSS or PCRF directly for this action.
a)
S-CSCF → HSS
→ Incorrect. The HSS is not involved in SIP BYE signaling—it handles user authentication and profile queries.
b)
P-CSCF → PCRF
→ Incorrect. PCRF manages policy/QoS, not SIP signaling.
c)
Callee → Caller
→ Incorrect. If the callee hangs up first, then this would be correct—but in this case, it’s the caller.
d)
Caller → Callee
→ Correct. The BYE is initiated by the caller and sent toward the callee to terminate the SIP session. The party terminating the call sends BYE to the peer.
