Whats is default username password for a Ericsson node?
(locally connected via LMT port, off course).
rbs/rbs
It looks like it is certificates mismatch between OSS and RBS.
You need to recomissioning RBS.
Also install proper license.
A new valid license key file is required for the second alarm.
For the first alarm, update the Node credential certificates. You can check it with “hget trusted content@issuer”
I don’t believe there is a need for recomissioning as it already has remote management access
hi, my friend.
how can i change the password en radio node for example Baseband 5216 6630.
I think would be in this right? MO SecM=1,UserManagement=1,UserIdentity=1,MaintenanceUser=1
There are many passwords: ldap, enrollment, rbs_user, …
Which password in particular do you need to change?
The password for user ‘local maintenance’ is required, so I think it would be ‘rbs_user.’
