DGE stands for dynamic gain equalization.
It’s a feature to avoid gain unflatness.
Allow gain flatness and power adjustment for long distances Links specially DWDM and submarine applications.
In long distances transmission we have to insert multiple stages of ILA.
ILA ( inline amplifier ) add enough Gain to the signal but adding several ILAs may lead to gain unflatness.
Some frequency channels will have gain values different from other channels.
And some frequency channels will be much more attenuation than others.
Then the gain curve become not flat as we increasing the number of cascaded ILAs.
DGE is a node to solve this issue and recover the difference between flat Gain and actual gain values.
It’s target to let all frequency channels have the same power values.
Through tilt equalizers and shape equalizers we can adjust the gain and power dynamically.
If OSNR degraded we have to use regeneration stage to recover the OSNR.
