Hi folks.
What tools can be used for MR coverage estimation (to show them on Map)?
In Huawei network, other than OMStar?
You can use NASTAR.
Genex Cloud.
Coverage Evaluation Tool.
WinsCloud.
Cloud based Mr analysis is very efficient, because the load will be on high speed, you just need to upload data.
Try Geo tool.
Hi all, thanks for the answers.
Are you aware of any non-Huawei tools that can do the job?
In which form you have data CSV?
I have only raw MR data.
If it is on Excel than you can import it on Mapinfo as a tab file.
Make sure to remove duplicate lat and long.
You can use also use Genex Discovery in Huawei
