5G Peak Data Rate (Throughput) is the highest data rate a cell achieves in ideal radio conditions, fully utilizing all available resources without error, measured in bits per second (bps).
It is measured in downlink (DL) and uplink (UL) with TDD (Time Division Duplex) or FDD (Frequency Division Duplex) modes.
Efficient use of Spectrum and optimal radio conditions are crucial for maximizing data rates.
Factors impacting data rates:-
- Modulation: Max 256QAM
- Overhead (OH): Varies by frequency
- J (number of carriers aggregated): Max 16
- f (scaling factor: mismatch in BB/RF): 1 (no mismatch)
- Coding rate: 0.93 (varies by error correction mechanism)
- Alpha (DL/UL resource proportion): 1 (FDD) and 0.76 (TDD)
- PRB (Physical Resource Block) varies by frequency range & bandwidth
- OFDM symbol duration and TDD frame structures influence performance
Understanding these factors helps optimize the potential of 5G networks for superior data rates and connectivity.
(Ref: ITU)
What peak data rates can be achieved in 5G (by Rahul Kaundal).pdf (2.2 MB)
