What is the main role of network automation in 5G?
Q. What is the main role of network automation in 5G?
a) Eliminate the use of physical antennas by replacing them with fully virtualized cloud-based networks.
b) Centralize the entire network control in a single base station for simplified service management.
c) Enable efficient management, configuration, and orchestration of network resources with dynamic service allocation and minimal manual intervention.
d) Ensure that all 5G communications operate only on fixed and static frequencies.
Check 🔎
:right_arrow: Correct answer: Letter c.
Network Automation in 5G enable efficient management, configuration, and orchestration of network resources with dynamic service allocation and minimal manual intervention.
a) :x: Eliminate the use of physical antennas by replacing them with fully virtualized cloud-based networks.
→ Incorrect. Physical infrastructure, like antennas, is still essential in 5G networks.
b) :x: Centralize the entire network control in a single base station for simplified service management.
→ Incorrect. 5G uses distributed and flexible architectures, not centralized control in one base station.
c) :white_check_mark: Enable efficient management, configuration, and orchestration of network resources with dynamic service allocation and minimal manual intervention.
→ Correct. This reflects the core role of automation in 5G networks.
d) :x: Ensure that all 5G communications operate only on fixed and static frequencies.
→ Incorrect. 5G uses dynamic spectrum allocation, not fixed/static frequencies.
