Hi (Ericsson Experts).
What is the command in Moshell to check EMCASW deployment?
I know ’ bbps’, but it doesn’t show on which EMCA UL and DL are deployed…
You can use below two command in order to check EMCASW.
lt all
→ This command lists the loaded targets (LT) in the system, and you can look for the EMCASW package in the output.
ltg | grep EMCASW
→ This will show the status of any EMCASW modules if they are deployed.
Hello.
We tried “ltg” command.
However it doesn’t work : ( “no such command: ltg”)
Maybe he means invl command to check SW packages.
What do you mean by EMCASW? explain…
