SDMA is a type of multiplexing technology used in mobile network.
Stands for space division multiple access.
Different from FDMA , TDMA , CDMA.
SDMA aims to use the same frequency channel on the same time and code by different users.
Sims to achieve high spectral efficiency.
To share the same channel among different users using SDMA we have to ensure the enough separation between uses.
SDMA can be implemented by using sector antenna 120 degree coverage.
Users can communicate using the same channel.
Beam forming technology used to let the antenna provide narrow beam focusing only on the destination user to avoid interference.
The main disadvantage of SDMA is the design complexity and hardware requirements for handset and site.
LinkedIn:
