What is beamforming?
Hello All.
After completing today session, you will able to know exactly answer of below questions:
  • What is beamforming in 5G?
  • What is factors that effect beamforming performance?
  • What is 3D or FD beamfomring?
  • What are types of beamforming?
  • What is transmision mode ™ in beamforming?
Youtube: 5G-NR Understanding|| Interview Questions || What is beamforming? - YouTube
How a User Equipment decodes the received beam from beamforming? Can UE generate beams to send data from UE to Base Station?
UE knows which precoding was used for construction of that beam. Then data is retrieved from DM-RS demodulation.
Yes, to generate narrow beams you need more antennas though. So real “beams” are particularly visible in case of UE communicating on FR2 (mmWave bands).
Hello dear experts.
Could you share which are the 3GPP standards that define beamforming?
UE is not informed about beamforming.
Only about csi-rs ports and n1n2 configuration.
Available in: 3GPP TS 38.214
Contains details about Type I and Type II Codebooks in 5G.
Beamforming antennas are a pivotal component in 5G networks, offering several critical advantages:
  1. Directional Signal Focus: Beamforming allows for focused transmission and reception of signal in specific directions, enhancing signal quality and strength.
  2. High-Frequency Utilization: 5G operates at high frequencies, often in the millimeter-wave spectrum, where beamforming is essential to combat signal loss and ensure reliable communication.
  3. Mobility Support: With 5G’s high-speed requirements, beamforming aids in maintaining connection quality during high-speed movements, such as in vehicles or trains.
  4. Interference Reduction: Narrow beams reduce interference by targeting users directly, which is especially beneficial in densely populated areas.
  5. Capacity Improvement: By directing beams where needed, beamforming improves network capacity, allowing more users to be served simultaneously.
  6. Enhanced Reliability and Latency: Beamforming contributes to lower latency and higher reliability, meeting the stringent demands of modern applications.
