In LTE/5G, before a UE can send any uplink data, it needs permission from the network — that’s the Uplink (UL) Grant.
- Sent by the gNB/eNB via DCI on the PDCCH
- Tells the UE exactly: which resource blocks, what MCS, how much power, and when to transmit
- Without it, the UE simply can’t transmit on PUSCH
Think of it as air traffic control for the uplink — no takeoff without clearance.
Two flavors worth knowing:
Dynamic Grant — allocated per transmission, most flexible
Configured Grant (Grant-Free) — pre-allocated resources, cuts latency for URLLC use cases
Small signaling detail, huge impact on network efficiency and latency. ![]()
Why is UL Grant needed?
MSG2 (RAR) MAC PDU Structure
UL Grant field breakdown (27 bits)
UE Processing Flow
Time-frequency resource mapping (MSG3 on PUSCH)
Practical example
Key takeaways
