gNodeB stands for “Next-Generation Node B” . It is a critical component of the 5G wireless network architecture. In 5G World , This is similar to Radio Station in BTS (2G) , NodeB (3G) , Evolved NodeB (4G) . gNodeB can also be deployed in a cloud-based infrastructure which supports in flexible and scalable network deployments
𝗢𝘃𝗲𝗿𝘃𝗶𝗲𝘄 𝗼𝗳 𝗴𝗡𝗼𝗱𝗲𝗕
Sending and receiving radio signals to and from 5G Radio & 5G User devices ( like smartphones and M2M / IOT devices )
Have capabilities to support 5G networks higher data rates, lower latency, increased device density, and improved overall performance
Supports high-speed data transfer for applications such as ultra-high-definition video streaming, virtual reality, and augmented reality
Handling a large number of connected devices at the same time, allowing for efficient connectivity for IoT devices, smart cities, and industrial automation for mMTC devices
Supports Low latency and high reliability for mission-critical applications such as autonomous vehicles, remote surgery, and industrial automation
Uses advanced antenna technologies for maximizing Spectral efficiency , Beamforming and MIMO
𝗧𝗮𝘀𝗸𝘀 𝗼𝗳 𝗴𝗡𝗼𝗱𝗲𝗕
Mobility management - Radio resource management , Radio signal processing
Connection management , packet processing & baseband processing
Security , Quality of service (QoS) & Charging
𝗡𝗴-𝗲𝗡𝗕 : 𝗡𝗲𝘄 𝘁𝘆𝗽𝗲 𝗼𝗳 𝗥𝗮𝗱𝗶𝗼 𝗶𝗻 𝟰𝗚 ( 𝗔𝗳𝘁𝗲𝗿 𝟱𝗚 𝗟𝗮𝘂𝗻𝗰𝗵 )
Since 5G Core supports both 4G & 5G Radio , There is need to introduce new type of eNB in 4G Radio Network : Ng-eNB to work with 5G Core
Ng-eNB allows users to connect to 5G core network using 4G radio interface (LTE RAN)
Credits:
