Q. What does the Subscription Data AVP in SAA contain?
a) RTP port numbers
b) Codec list
c) Bearer TLVs
d) Initial Filter Criteria list
Check 🔎
Correct answer: Letter d.
The Subscription Data AVP in the SAA (Server-Assignment-Answer) message contains the Initial Filter Criteria list, which defines the policy and charging rules for the subscriber’s sessions.
a)
“RTP port numbers”
→ Incorrect. RTP port numbers are negotiated in session setup, not via Subscription Data AVP.
b)
“Codec list”
→ Incorrect. Codec info is handled in session signaling, not in Subscription Data AVP.
c)
“Bearer TLVs”
→ Incorrect. Bearer TLVs are part of lower-layer bearer management, not Subscription Data AVP.
d)
“Initial Filter Criteria list”
→ Correct. The Initial Filter Criteria list specifies the subscriber’s policy and charging control information. Subscription Data holds the user profile including iFCs.
