WDM trail is the route or logical path where we Transport the traffic
Trail can be created by NMS
We have 2 main categories of Trails :
Electrical & Optical Trails
Electrical trails has 3 types :
- Client
- ODU
- OTU
Optical Trails has 4 types :
- OCH
- OMS
- OTS
- OSC
Each trail has its limits , for example Client trail is between client side ports of the OTU in source and sink sites
OTU is the transponder which used for OTN framing and colorless/ colored mapping
Client trail also created with Tributary and line boards
ODU Trail is created using the Internal logical Port of transponder or tributary/ Line
OCH is optical trail created between optical modules of the transponders in both source and sink sites
OSC trail is optional and it’s for DCN mangment to carry the supervisory signal between OSC boards in both ends
OMS is between MUXs and Demuxs
OTS is the physical fiber between sites which Carry multiplexed signals
To create the trail on NMS you have to configure the source and sink shelf , board , port , wavelength , Trail capacity
I explained with screenshot how to create the trail in previous posts you can check
