VoNR Deep Dive (End-to-End Call Flow Explained)
:satellite_antenna: VoNR = IMS over 5G Core
Unlike VoLTE (which uses 4G EPC), VoNR works with:
:check_mark: 5G Radio (NR)
:check_mark: 5G Core (AMF / SMF / UPF)
:check_mark: IMS (for call control using SIP)
:backhand_index_pointing_right: This is a fully end-to-end 5G voice solution
:brain: Key Network Elements
  • :mobile_phone: UE (your phone)
  • :satellite_antenna: gNodeB (5G base station)
  • :compass: AMF (access & mobility control)
  • :globe_with_meridians: SMF (session management)
  • :rocket: UPF (user plane data path)
  • :telephone: IMS (handles call signaling via SIP)
:gear: VoNR Call Flow (Step-by-Step)
:small_blue_diamond: Step 1 β€” 5G Registration (Precondition)
:mobile_phone: UE β†’ :satellite_antenna: gNB β†’ :compass: AMF
:check_mark: UE is already registered on 5G Core
:check_mark: PDU session is active
:backhand_index_pointing_right: Data connectivity exists before the call
:small_blue_diamond: Step 2 β€” IMS Registration
:mobile_phone: UE β†’ :telephone: IMS (via UPF)
:backhand_index_pointing_right: SIP REGISTER message sent
:check_mark: UE becomes reachable for voice calls
:small_blue_diamond: Step 3 β€” Call Initiation
:backhand_index_pointing_right: SIP INVITE sent
:check_mark: Call setup begins
:small_blue_diamond: Step 4 β€” Call Routing
:telephone: IMS routes the call
:check_mark: Finds destination UE
:check_mark: Establishes session path
:small_blue_diamond: Step 5 β€” QoS Flow Setup (Critical)
:globe_with_meridians: SMF + :rocket: UPF
:backhand_index_pointing_right: Create dedicated QoS Flow
:check_mark: Uses 5QI (e.g., 5QI = 1 for voice)
:check_mark: Guarantees:
  • Low latency
  • High priority
:small_blue_diamond: Step 6 β€” Voice Path Established
:mobile_phone: β†’ :satellite_antenna: gNB β†’ :rocket: UPF β†’ :telephone: IMS β†’ :mobile_phone:
:backhand_index_pointing_right: Voice packets flow over 5G user plane
:small_blue_diamond: Step 7 β€” Call Connected
:check_mark: Two-way communication begins
:backhand_index_pointing_right: Fully over 5G (no LTE fallback)
:bar_chart: Control vs User Plane
:brain: Control Plane:
:mobile_phone: β†’ :satellite_antenna: gNB β†’ :compass: AMF β†’ :globe_with_meridians: SMF β†’ :telephone: IMS
:rocket: User Plane:
:backhand_index_pointing_right: Clean separation = better performance
:light_bulb: Simple Analogy
Think of VoNR as:
:rocket: A VIP fast lane created instantly for your call
:backhand_index_pointing_right: Your voice doesn’t compete with normal data
:backhand_index_pointing_right: It gets priority + guaranteed quality
:warning: Why VoNR is Not Widely Available Yet
:backhand_index_pointing_right: Requires:
:check_mark: 5G Standalone (SA)
:check_mark: IMS support
:check_mark: Device compatibility
:backhand_index_pointing_right: That’s why today:
:telephone_receiver: Calls still mostly use VoLTE fallback
:backhand_index_pointing_right: Initially:
  • Voice will remain on VoLTE
  • VoNR will come with SA deployment
:backhand_index_pointing_right: Future:
:check_mark: Faster call setup
:check_mark: Better voice quality
:check_mark: Lower delay
:bar_chart: In Simple Words
VoLTE = Voice on 4G VoNR = Voice on true 5G
:backhand_index_pointing_right: Same concept… but more advanced
:fire: Final Insight
:backhand_index_pointing_right: Voice is evolving from:
:telephone_receiver: Basic communication
:right_arrow:
:rocket: Priority-based, low-latency service
HI
Control plane for a voice call wont go through AMF and very few messages needed for UDM and PCRF query even reach SMF and we dont consider them as control plane messages for a voice call.IMS default bearer tunnel is directly via UPF.
Correct control plane flow
UEβ€”β†’gNB—–>UPFβ€”β€”>PCSCF
Correct User plane flow
UEβ€”β€”>gNB—–>UPFβ€”β€”β†’iBGF/MGWβ€”β€”β†’eBGF/MGW or iBGF/MGW.
thank you
Kind regards
Isuru
Hi,
QoS modification for voice requires:
SMF involvement
PCF policy update
So for NAS / Network Control
UE β†’ gNB β†’ AMF β†’ SMF β†’ PCF
:check_mark: Registration
:check_mark: Session control
:check_mark: QoS control
For IMS / SIP Control
UE β†’ gNB β†’ UPF β†’ P-CSCF β†’ IMS
:check_mark: Call setup (INVITE, 200 OK)
