If you are looking for a high gain 5G cellular BTS antenna, so it is worth to check this: an antenna with one of the highest gain ratings available on the market!
If your subs are experiencing slow 5G speeds or poor signal strength in the 3300 MHz - 3950 MHz frequency range, It may be time to consider using a high-gain, narrow beam cellular BTS antenna!
The VEGA (Very High Gain Antenna) CMW12 WB3 is the most flexible & cost-effective solution to some of the more pressing 5G coverage challenges in Cellular Access Networks. VEGA’s ±45° dual slant polarization design combines high gain with dual polarization and a truly narrow beam making it an ideal solution to 5G service for long corridor coverage, highways, railways and remote sub clusters.
Bands 3300-3950 MHz
2X2 MIMO
Gain +26dBi (especially attractive for cellular remote FWA applications)
Read more:
