Understanding the Four Critical Links in LEO Satellite Networks
From User Connectivity to the Fiber Backbone
LEO satellite connectivity is not simply about transmitting data between a user terminal and a satellite. It depends on an integrated architecture combining space-based links with high-capacity terrestrial fiber infrastructure.
Understanding the relationship between four essential components is key to understanding how modern LEO networks operate.
1. Service Link – User to Satellite
The Service Link connects the User Terminal (UT) directly to the LEO satellite.
It carries uplink and downlink traffic, enabling broadband connectivity for users, enterprises, and remote locations.
Its performance depends on factors such as frequency bands, antenna tracking, link budget, Doppler compensation, and satellite mobility.
2. Feeder Link – Satellite to Gateway
The Feeder Link connects the satellite to a Satellite Gateway (Earth Station).
It carries aggregated traffic between the space segment and the terrestrial network, typically using Ka-band or other allocated frequency bands, depending on the system design.
Gateway selection, spectrum availability, atmospheric attenuation, and link capacity are critical engineering considerations.
In LEO constellations using Inter-Satellite Links (ISLs), traffic may travel through multiple satellites before reaching a suitable gateway.
3. Fiber Backhaul – Gateway to Network
Once traffic reaches the Satellite Gateway, it enters the terrestrial transport network.
Fiber Backhaul carries this traffic from the gateway to network Points of Presence (PoPs), aggregation sites, or core network facilities.
Technologies such as 100G/400G Ethernet, DWDM, and OTN can support high-capacity transport, depending on network requirements.
4. Fiber Backbone – The National and Regional Transport Layer
The Fiber Backbone provides the high-capacity infrastructure connecting major cities, data centers, Internet Exchange Points (IXPs), core networks, and international gateways.
It aggregates traffic from multiple gateways and other access networks, providing scalability, redundancy, and efficient traffic distribution.
How do these four components work together?
User Terminal → Service Link → LEO Satellite → Feeder Link → Satellite Gateway → Fiber Backhaul → Fiber Backbone → Core Network / Internet.
The reverse path carries the response back to the user.
An Important Engineering Distinction
Service Link and Feeder Link operate in the satellite radio segment, while Fiber Backhaul and Fiber Backbone operate in the terrestrial optical transport segment.
They are not interchangeable.
The performance of an LEO network depends not only on satellite capacity, but also on gateway availability, fiber capacity, routing efficiency, latency, and end-to-end network resilience.
The key principle:
A satellite provides access from space, but fiber infrastructure carries that connectivity into the wider digital ecosystem.
Neither segment should be engineered in isolation
