Understanding of Default and Dedicated Bearer in LTE.
Experts can comment further.
- UE always have 1 default bearer which is non gbr.
- For same APN other bearers are dedicated which can be gbr or non gbr.
Queries:
- How many max dedicated bearer per UE, per APN?
- Can we say EPS barer id same for default and dedicated bearer if both configured for same UE?
S_K
2
EPS bearer ID is different for each bearer (generally 5-QCI9, 6-QCI5, 7-QCI1).
Ok, so it mean if 1 UE having 2 bearer one default and one dedicated, then EPS bearer ID different for both?
Ok thanks
And what max value per UE?
S_K
6
I don’t have exact idea about max limit, but I don’t think there is any limitation.
Whatever bearer configured in the system, UE can support it?
Nitin
7
I would say 31, based on lcid.
But have never tested more than 8.
Hainm
8
maximum 11 EPS bearer: 5 -> 15
