From 4G’s QPSK to 6G’s AI-Driven Waveforms: The Journey of Efficient Bits
What is Modulation?
Modulation maps digital data onto analog waveforms for over-the-air transmission. In 5G NR, this is done Resource Element (RE)-wise. A modulation symbol’s order defines how many bits each symbol carries:
• QPSK (2 bits/symbol),
• 16QAM (4),
• 64QAM (6),
• 256QAM (8).
3GPP 38.211 Reference:
Modulation is defined per channel—PUSCH, PDSCH, PUCCH, etc. Each uses a specific scheme depending on link conditions, UE capability, and network strategy.
Scheme Bits/Symbol Used In
π/2 BPSK 1 PUSCH, PUCCH Format 3/4
QPSK 2 PUSCH, PDSCH, PUCCH, PBCH, PDCCH
16QAM 4 PUSCH, PDSCH
64QAM 6 PUSCH, PDSCH
256QAM 8 PDSCH
π/2 BPSK – The Unsung Hero
In poor coverage, π/2 BPSK shines with:
Lower Peak-to-Average Power Ratio (PAPR),
90° rotation per symbol → avoids “zero-crossings”,
Better battery efficiency due to simpler amplifier operation.
Modulation Equation:
For constellation-based modulations:
Bits per symbol = log_2(M)
Where M = number of constellation points (e.g., 256QAM → log_2(256) = 8 bits/symbol)
From 4G to 5G to 6G: What Changed?
• 4G LTE: Limited to QPSK, 16QAM, 64QAM.
• 5G NR: Adds 256QAM + π/2 BPSK + adaptive modulation + DFT-s-OFDM in uplink.
• 6G (evolving): Introduces Reconfigurable Intelligent Surfaces (RIS), AI-driven adaptive modulation, sub-THz frequencies—modulation becomes environment-aware!
Code Insight (Python-based Constellation Visualisation):
import numpy as np
import matplotlib.pyplot as plt
def qam_constellation(M):
m = int(np.sqrt(M))
x = np.arange(-m+1, m+1, 2)
X, Y = np.meshgrid(x, x)
plt.scatter(X.flatten(), Y.flatten())
plt.title(f’{M}-QAM Constellation’)
plt.grid(True)
plt.show()
qam_constellation(64) # Visualise 64QAM
Real Use Case:
• Rural Coverage: π/2 BPSK → lower power, deeper penetration.
• Urban High Capacity: 256QAM → more bits, higher throughput.
Takeaway:
Modulation isn’t just math. It’s the language of connectivity, optimizing the tradeoff between robustness and data rate—from edge UEs in remote zones to 8K streaming in smart cities.
Let’s decode complexity into curiosity!
