How to read this featuresetsdownlink?
Does this mean UE cant support 15KHz SCS?
Does this mean UE cant support 2 layer MIMO?
What is difference between supported BandwidthDL & Channel BW here?
Hello dear, this picture means that:
The UE cab support 90Mhz/30Khz/ MIMO(4)
Check here: Band combinations in NR capabilities
@Sareenr featuresetsdownlink cannot be interpreted in isolation of the rest of the UE capability message
For each supported band combiniation, there is a reference to featureset combination which references feature set list for DL which references the featuresetsdownlinkyou are asking about.
In simple words, your screenshot is feature set for a specific NR band supported by the UE and other bands will have same or different featuresetsdownlink
