Purpose of Attenuators:
In WDM systems, attenuators are used to control and adjust optical power levels. -
Types of Attenuators:
- Fixed attenuators apply a constant dB value.
- Variable attenuators allow dynamic control of attenuation.
Control Methods:
Variable attenuators can be adjusted mechanically or electronically (remotely). -
Remote Operation:
Electronically controlled attenuators donโt require on-site visits for power adjustments. -
DCMs - Dispersion Compensation Modules:
Used to compensate for signal dispersion over long distances. -
Types of Dispersion:
- Chromatic Dispersion (different wavelengths travel at different speeds)
- Polarization Mode Dispersion (caused by light polarization changes)
Coherent Systems:
These systems handle dispersion electronically within the WDM transponder. -
No DCMs Needed:
Coherent systems eliminate the need for physical DCMs.
