Understand each IE of NR Capability info
Any public link /doc there to understand each IE of NR Capability info other then 3gpp?
Yes, here is one I am using a lot:
https://itectec.com/spec/5g-nr-ue-capability-parameters/
Just do a CTRL + F for every IE and it is there.
Any IE is there! :+1: :slight_smile:
Also with a brief explanation.
But those are UE capab just for 5G.
For 4G are not there, so lot of IE for 4G will be missing.
Thank you very much for the tip! :+1: :slight_smile:
5G only required, very complicated to refer 3gpp.
3GPP TS 38.306 is your way to go
And its old friend, 36.306 :slight_smile:
