ul/dlTrafficDelay per gnB to compensate delays
Dear Expert,
I have a question, do you know how works the parameters ul/dlTrafficDelay per gNB when you need to compensate a delay created, for example, by a DAS?
Do you know how easy and flexible it is to change that parameter in a node attached to the DAS? Is it traffic affecting?
Do you know if there is a default value used for macrosites?
got any response from this, what meand to have those 2 in -1 vs 32 for example?
