Ryan
#1
Hi all 5G Experts.
With Amarisoft I have attach and all fine, but once I use real UE then I don’t see that UE send any ACK on MSG4 (RRC setup message).
I see MSG1, MSG2, MSG3 and on MSG4 UE isn’t sending ACK.
So with real uE stuck on MSG4 / MSG5.
Any idea what could be the reason?
It’s 5G SA deployment.
At UE end see if you are able to check setup - msg4 than it’s stuck on msg4.
That’s why not sending msg5.
Need to check gNB parameters for RRC setup.
Ryan
#3
Thanks.
But why with Amarisoft it works?
It’s a Simulator., while comercial UE has different implementation.
You need to tune RRC setup parameters.
Which UE are you using?
Check UAC BARRING FACTOR. How much it is…
