What is the difference between Type II Codebook and Type II port selection codebook? Where are these codebooks used?
This can help you to understand:
What is a codebook and it’s relation to PMI?
Precoding
- Precoding is a digital signal processing technique used to improve the performance of the communication system.
- It involves the multiplication of the transmit signal by a precoding matrix, which is selected from the codebook.
- The precoding matrix is chosen based on the channel state information (CSI) available at the transmitter.
- This information is typically obtained through a feedback mechanism from the receiver (PMI).
Codebook in 5G
- A codebook is a predefined set of complex valued matrices that represent various spatial precoding weights.
- These weights are applied to the transmitted signals to improve the performance of the wireless link.
- The codebook is designed based on certain criteria, such as maximizing the SNR at the receiver or minimizing the interference to other users in the network.
- The codebook is indexed, and the index of the selected precoding matrix is fed back to the transmitter by the receiver using PMI.
- When a receiver selects the most suitable precoding matrix from a codebook based on the current CSI, it sends the PMI back to the transmitter.
- The transmitter then applies the corresponding precoding weights to the transmitted signals.
- This process helps to focus the transmitted energy towards the desired receiver (beamforming), thus improving the signal quality and mitigating interference.
Codebook Types in 5G
- Type I - Single Panel
- Type I - Multi Panel
- Type II - Single Panel
- Type II - Port Selection
Credits: ![]()
