Turning raw telecom data into smart, interactive maps!
:satellite_antenna: Meet Dataviz – turning raw telecom data into smart, interactive maps!
Developed as part of an academic outreach initiative, Dataviz was created to solve a real problem: the difficulty of interpreting and visualizing technical data from the telecommunications sector.
With Dataviz, you can:
:white_check_mark: Upload your CSV file with station data
:white_check_mark: Generate your own CSV file with your station information
:white_check_mark: Visualize coverage areas and azimuths directly on maps
:white_check_mark: Generate KML files from existing CSVs
:white_check_mark: Create KML files with multiple customizable parameters
:white_check_mark: Understand the telecom sector in a visual, intuitive, and educational way
:light_bulb: All designed with a focus on education, transparency, and technical accessibility—especially useful for students, technicians, and professionals in the field!
:link: Try the tool: Ultima Milha - Análise de Dados
:movie_camera: Watch the tutorial video on YouTube: https://youtu.be/LkewqVk25SU
:backhand_index_pointing_right: Liking, commenting, and subscribing makes a real difference! Your support helps validate this project at the university and increases its visibility for those who need it.
:pushpin: Use the tool, comment below, share, and tag me! Your engagement counts a lot.
Very good! Congratulations on the work… I would certainly use the tool!
PS: The YouTube video continues at the end of the concept presentation, but without audio.
Thanks! Yes, the video at the end has no audio because it’s only demonstrating another integrated tool.
I’m still not getting the engagement I need — I’m currently in the promotion phase.
Okay, I understand. Great initiative!
I’m curious about something: would it be possible to see in ANATEL’s reports which private networks (MPN) are registered or already in operation? What do you think?
Regarding engagement: stay active on LinkedIn, create a page for your tool, etc. I believe you’ll get more interactions there.
Best regards!
Great work. That tool looks really amazing in terms of analyzing and visualizing the telecom data.
