Troubleshooting: Site Active but No UE Attached
What should I check if the site is operational, but no UE is attaching?
Thanks!
“No UE attach” on which type of sites? 2G, 3G, 4G, or 5G?
4G site.
Is the UE triggering any RACH attempts?
My engineer is at this site but is unable to attach, even though the cells are up.
It’s likely a configuration issue with the CGI/TAC.
Verify the site’s planning data against the implemented configuration.
Have you checked the APN settings?
The TAC is correct. How can I check the CGI in Ericsson ENM?
Try this command: st cell=sectorID -t
I’m not an Ericsson expert, but I found this in a document.
Can you check it on the eNodeB using Moshell?
Yes, which command should be used?
It must be checked from the core side, as the attach procedure is transparent to the RAN.
Did your engineer try connecting to other cells on the same site?
The issue affecting the entire site.
Please check if there are any alarms.
Engage your RAN team to verify all IPs, including O&M and MME UP addresses.
Use the following commands:
  • alt command
  • st cell
  • get EUtranCell tac
  • get EUtranCell cellid
Is it FDD or TDD?
You can also check with a trace by IMSI from the MME side. Engage your Core team for assistance.
The TAC is not defined in the TAC-LAC mapping in DNS.
