Dear experts,
In one of our LTE sites, Carrier Aggregation (CA) is not functioning.
Which configuration parameters should be checked to identify the cause?
Dear experts,
Hardware?
Ericsson BB 6630.
Which CA feature are you using - ERAN or Inter eNodeB CA?
Both can serve as fallbacks for each other but require separate configurations.
This assumes that the necessary relations are established and sCellCandidate is enabled.
Yes, sCellCandidate is enabled.
Is Carrier Aggregation (CA) configured between basebands (BB)?
No, the Carrier Aggregation (CA) is configured between cells.
