š—Ŗš—µš˜† š—›š—¶š—“š—µš—²š—æ š—¢š—æš—±š—²š—æ š—¤š—”š—  š—™š—®š—¶š—¹š˜€ š—¶š—» š—„š—²š—®š—¹ š—”š—²š˜š˜„š—¼š—æš—øš˜€
šŸ²šŸ°š—¤š—”š—  looks incredible on paper higher spectral efficiency more bits per symbol and huge theoretical capacity.
But in real networks especially long haul APAC routes it often collapses instantly.
The reason is simple
š—›š—¶š—“š—µš—²š—æ š—¼š—æš—±š—²š—æ š—¤š—”š—  š—¶š˜€š—»š˜ š—¹š—¶š—ŗš—¶š˜š—²š—± š—Æš˜† š—ŗš—¼š—±š˜‚š—¹š—®š˜š—¶š—¼š—» š˜š—µš—²š—¼š—æš˜†
š—œš˜ š—¶š˜€ š—¹š—¶š—ŗš—¶š˜š—²š—± š—Æš˜† š—¢š—¦š—”š—„
As you push from š—¤š—£š—¦š—ž → šŸ­šŸ²š—¤š—”š—  → šŸ²šŸ°š—¤š—”š—  the constellation points tighten the decision boundaries shrink and the signal becomes extremely sensitive to
• phase noise
• nonlinear interference
• filter narrowing
• ROADM insertion loss
• accumulated ASE from EDFAs
In short
š˜š—µš—² š—°š—®š—½š—®š—°š—¶š˜š˜† š˜†š—¼š˜‚ š˜„š—®š—»š˜ š—±š—²š—½š—²š—»š—±š˜€ š—²š—»š˜š—¶š—æš—²š—¹š˜† š—¼š—» š˜š—µš—² š—¢š—¦š—”š—„ š˜†š—¼š˜‚ š—µš—®š˜ƒš—²
This is why šŸ°šŸ¬šŸ¬š—š QPSK or 16QAM is robust across most APAC fibers
and šŸ²šŸ°š—¤š—”š—  is realistically a metro only modulation format.
š—–š—¼š—µš—²š—æš—²š—»š˜ š—¼š—½š˜š—¶š—°š˜€ š—¶š˜€š—»š˜ š—®š—Æš—¼š˜‚š˜ š—°š—æš—®š—ŗš—ŗš—¶š—»š—“ š—ŗš—¼š—æš—² š—Æš—¶š˜š˜€ š—¶š—»š˜š—¼ š—® š˜€š˜†š—ŗš—Æš—¼š—¹
š—œš˜ š—¶š˜€ š—®š—Æš—¼š˜‚š˜ š˜„š—µš—²š˜š—µš—²š—æ š˜†š—¼š˜‚š—æ š—³š—¶š—Æš—²š—æ š—®š—»š—± š—¢š—¦š—”š—„ š—°š—®š—» š—øš—²š—²š—½ š˜š—µš—¼š˜€š—² š—Æš—¶š˜š˜€ š—®š—¹š—¶š˜ƒš—²
šŸ²šŸ°š—¤š—”š—  š—¹š—¼š—¼š—øš˜€ š—½š—²š—æš—³š—²š—°š˜ š—¶š—» š—¹š—®š—Æš˜€.
š—œš—» š—æš—²š—®š—¹ š—³š—¶š—Æš—²š—æ š—»š—²š˜š˜„š—¼š—æš—øš˜€ š—¶š˜ š—Æš—æš—²š—®š—øš˜€ š—³š—®š˜€š˜.
Where theory ends and physics begins.
š—›š—¶š—“š—µš—²š—æ š—¢š—æš—±š—²š—æ š—¤š—”š—  š—¶š˜€ š—»š—¼š˜ š—® š—°š—®š—½š—®š—°š—¶š˜š˜† š˜‚š—½š—“š—æš—®š—±š—².
š—œš˜ š—¶š˜€ š—®š—» š—¢š—¦š—”š—„ š—°š—µš—®š—¹š—¹š—²š—»š—“š—².
More bits per symbol only work if the signal quality can keep them separated.
š—”š˜€ š—ŗš—¼š—±š˜‚š—¹š—®š˜š—¶š—¼š—» š—¶š—»š—°š—æš—²š—®š˜€š—²š˜€ š˜€š—²š—»š˜€š—¶š˜š—¶š˜ƒš—¶š˜š˜† š—²š˜…š—½š—¹š—¼š—±š—²š˜€.
Constellation points move closer.
Decision margins shrink.
Small noise becomes fatal.
š—œš˜ š—¶š˜€ š—»š—²š˜ƒš—²š—æ š—·š˜‚š˜€š˜ š—¼š—»š—² š—¶š—ŗš—½š—®š—¶š—æš—ŗš—²š—»š˜.
š—”š—¼š—»š—¹š—¶š—»š—²š—®š—æ š—±š—¶š˜€š˜š—¼š—æš˜š—¶š—¼š—»
š—˜š——š—™š—” š—”š—¦š—˜ š—»š—¼š—¶š˜€š—²
š—–š—µš—æš—¼š—ŗš—®š˜š—¶š—° š—±š—¶š˜€š—½š—²š—æš˜€š—¶š—¼š—»
š—£š— š——
š—„š—¢š—”š——š—  š—³š—¶š—¹š˜š—²š—æš—¶š—»š—“
They stack until the constellation collapses.
š—œš—» š—¹š—®š—Æš˜€ šŸ²šŸ°š—¤š—”š—  š—¹š—¼š—¼š—øš˜€ š—Æš—²š—®š˜‚š˜š—¶š—³š˜‚š—¹.
š—œš—» š—æš—²š—®š—¹ š—³š—¶š—Æš—²š—æ š—¶š˜ š—±š—¼š—²š˜€ š—»š—¼š˜.
Perfect fibers do not exist in live networks.
š—”š—£š—”š—– š—¹š—¼š—»š—“ š—µš—®š˜‚š—¹ š—»š—²š˜š˜„š—¼š—æš—øš˜€ š—®š—æš—² š—µš—®š—æš˜€š—µ š—²š—»š˜ƒš—¶š—æš—¼š—»š—ŗš—²š—»š˜š˜€.
Mixed š—š.šŸ²šŸ±šŸ® š—®š—»š—± š—š.šŸ²šŸ±šŸ± fiber
Variable splicing quality
EDFA only amplification
Long ROADM chains
High order QAM suffers first.
šŸ²šŸ°š—¤š—”š—  š—°š—®š—» š˜„š—¼š—æš—ø š—¶š—» š—°š—¹š—²š—®š—» š—ŗš—²š˜š—æš—¼ š—¹š—¶š—»š—øš˜€.
š—œš˜ š—³š—®š—¶š—¹š˜€ š—¼š—» š—¹š—¼š—»š—“ š—µš—®š˜‚š—¹.
That is why šŸ°šŸ¬šŸ¬š—š š—¤š—£š—¦š—ž š—®š—»š—± šŸ­šŸ²š—¤š—”š—  remain the backbone workhorses.
š—–š—¼š—µš—²š—æš—²š—»š˜ š—¼š—½š˜š—¶š—°š˜€ š—¶š˜€ š—»š—¼š˜ š—®š—Æš—¼š˜‚š˜ š—°š—æš—®š—ŗš—ŗš—¶š—»š—“ š—ŗš—¼š—æš—² š—Æš—¶š˜š˜€.
š—œš˜ š—¶š˜€ š—®š—Æš—¼š˜‚š˜ š—øš—²š—²š—½š—¶š—»š—“ š˜š—µš—¼š˜€š—² š—Æš—¶š˜š˜€ š—®š—¹š—¶š˜ƒš—².
Capacity without margin is not engineering.
It is risk.
š—Ŗš—®š—»š˜ š˜š—¼ š˜‚š—»š—±š—²š—æš˜€š˜š—®š—»š—± š—¢š—¦š—”š—„ š—ŗš—¼š—±š˜‚š—¹š—®š˜š—¶š—¼š—» š—Æš—®š˜‚š—± š—æš—®š˜š—² š—®š—»š—± š—æš—²š—®š—¹ š—»š—²š˜š˜„š—¼š—æš—ø š—¹š—¶š—ŗš—¶š˜š˜€
:blue_book: š——š—²š—ŗš˜†š˜€š˜š—¶š—³š˜†š—¶š—»š—“ š——š—Ŗš——š—
Built for engineers who design real optical networks.
